I'm curious to see what the story behind some discontinued products is, for example the silverstone tj07, usually when I see something as 'discontinued' my first thought is oh well some manufacturing problem probably, but then I read product reviews and it's not mentioned? So here's the questions for you all, how does this work, why are products discontinued on some sites and not others, and have you ever wanted a product which was discontinued?
I really wanted a SSTJ07:(
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/59617-discontinued-products/
Usually happens when they release a newer version of it. Check ebay for a TJ07 and I bet they have it.
Also, the TJ11 is sexy.
4j8Z39u.jpg?1
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808749
time to do some investigation on this case
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808754
If I remember correctly that looks like Linus's case.
it does thats where I saw it, I love the outside case design
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808755
You might find another Silverstone case you like. The RV series are nice too
http://www.silverstonetek.com/product_case.php?tno=0&case=c_tower&area=en
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808768
Not "discontinued" in US but brings quite an upset on these forums: Swiftech H220
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808772
I can drive an hour north and get one from NCIX when they got them in stock
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808781
Is there a certain name for that case layout? Front of the case and HD cages are on the left.
It just a 90 degree rotation on the inside that Silverstone is known for
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808784
Discontinued only means that it is no longer for purchase. For example, the TJ07 is what, 8 years old at this point? It is no longer in production, therefore stores can only sell whatever stock they have left, once that stock is sold, they can't sell anymore, ergo discontinued.
Discontinued does not mean there are/were problems with said product.
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808808
Can you explain what you mean here? I've got an h220, so I'm just wondering why it makes "quite an upset".
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808873
Can't buy it in America :P
https://linustechtips.com/topic/59617-discontinued-products/#findComment-808876
I must be lucky then.  I'm in Amercia and I got mine from Newegg.
https://linustechtips.com/topic/59617-discontinued-products/#findComment-810697
I got mine as soon as they came out.  Good thing I didn't wait.  I'll sell mine to somebody in the US if they want to pay me enough for it
https://linustechtips.com/topic/59617-discontinued-products/#findComment-821441
If it was good they wouldn't of discontinued it. Linus himself has listed the issues and if you've seen his videos know what those are as well, then they cheapened it up, which Linus also goes on and on how the newer models are not as good, hence "Discontinued".
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
https://linustechtips.com/topic/59617-discontinued-products/#findComment-822486
