So after a clean install, i just went casually on Youtube to listen to music, but something was different....... the music didnt sound as epic as it did before.
i do have RealTek audio driver installed From gigabytes webiste.
i also have the SoundBlaster X-Fi that i had before, but the sound just isnt the same.
Hmm:
-the jack i used to use for headphones i no longer can repurpose it , why ? on old installation i could repurpose it to mic/front speakers/headphones/ and others....
-I also dont have the option to change Hz in Realtek HD audio manager for my headset , there are only 3 tabs (Speaker Conf. , Room Correction and Default Format)
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/596114-need-help-setting-up-audio/
Hmm:
Then the driver install isn't correct.  You have the wrong driver or didn't install it properly.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
i tried it both from Realtek.tw and Gigabytes website, same thing.
but the drivers date is 2015/6/25 , which seems a bit old. I guess ill wait for a driver update from gigabyte appcenter.
you shouldn't install genetic drivers. Always get them from your manufactures' website.
