Hi all,
I'm looking for a usb hub with audio jacks so I can access these ports from my desk instead of climbing under to awkwardly reach my PC.
The aim is to replace the hub in my keyboard that I use, since I'm getting a new keyboard and <80% keyboards with usb and audio hubs are hard to find. I often plug speakers in and out via a 3.5mm audio jack, I also often use USB for my headset and memory sticks / any extra stuff I end up using.
Any recommendations for USB/audio hubs? I've heard it's better to get a powered hub. The trouble is finding one that does audio too, would I be better of getting a USB to audio jack adapter separately and just plugging that in? Braided cable would be awesome but you can't always be that picky.
https://linustechtips.com/topic/596108-usb-hub-with-audio-jacks/
Might as well get a regular USB hub and a 3.5 to USB adapter
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/596108-usb-hub-with-audio-jacks/#findComment-7745706
