1 hour ago, FillureN said:
I am building a MATX build in which i need help finding a good 1151 socketed motherboard for gaming. It can be mitx if there is a good one, but i'd rather choose matx.
I have a budget of 200$ for the mobo
ty
give us entire budget, well make a build for you
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7743800
2 hours ago, FillureN said:
What's your whole build and budget? What are using your PC for?
 You'll probably end up with one of the MSI VD or Gaming H110/B150 boards
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744218
as said to Bajantech
I have everything I just need a motherboard that fits with both amd and gtx cards, and aswell can do a skylake i7 processor.
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744260
any motherboard will support gtx and amd cards.
it is the case that does not support them.
msi, asus, evga, and gigabyte are reputable companies
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744289
Ok. That means that I am only out for a motherboard that is M-ATX and supports lga 1151 :D. Sounds simple enough!
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744299
As in you bought everything but your motherboard?
https://pcpartpicker.com/part/msi-motherboard-b150mprovd
Solid power delivery with USB 3.1 only 4 sata if that matters, probably won't
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744305
12 minutes ago, Streetguru said:
Exactly as in I have bought everything. I wanted to be a bit more meticulous about my motherboard, since it is not as easily replaced.
Also seems like a solid pick you made on the motherboard. Thank you!
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744334
If you want something with some extra gimmicks look to the fatal1ty boards, though they lack USB 3.1 at the low end
https://linustechtips.com/topic/595921-help-for-pc-needed/#findComment-7744353
