Hey Guys. Im helping a friend to make a choice from what processor is kinda better. The FX 8370 vs the Intel i7-6700k? Hes damn rich so maybe other necssary components will be bought if it is needed or what is required by that processor. All he wants to know is what it id better, faster and all. So, what is better guys?
https://linustechtips.com/topic/595774-choice-help/
http://cpuboss.com/cpus/Intel-Core-i7-6700K-vs-AMD-FX-8370
that should tell you everything you need but simply put the i7 generates less heat uses less energy and its overall faster. it also has quite a bit of overclocking headroom, dont know how much the FX has.
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
https://linustechtips.com/topic/595774-choice-help/#findComment-7742442
Im a total noob about this things. But AMD boasts a lot of cores. Doesnt that help? Cores is where you put tasks right?
https://linustechtips.com/topic/595774-choice-help/#findComment-7742458
 threads  are what process the tasks and in this case the FX has 8 cores and each core has 1 thread but the i7 has 4 cores and each core has 2 threads so both have 8 threads. The thing in amd cpus is that they have crazy high stats but their performance is nowhere near Intel processors. And cores are not as important as Ghz and as the i7 can be overclocked it will be a lot better.  I know it can be confusing but you'll get a hang of it  ?
https://linustechtips.com/topic/595774-choice-help/#findComment-7742475
if you friend had the cash to spend even i saying this go i7-6700k, this is the latest chip intel can offer, but if your friend is not even in a hurry try to wait zen and will see if amd can beat or get in par with intel.
GAMING RIG
i5 4590 / 16GB / RX 480 8GB
https://linustechtips.com/topic/595774-choice-help/#findComment-7742567
Yes. He is definitely rich. And can totally wait too, will the Zen from AMD outplay the i7?
https://linustechtips.com/topic/595774-choice-help/#findComment-7743077
