CPU cooler
Go to solution Solved by DioOmicida,
6131_23_be_quiet_dark_rock_3_cpu_cooler_
It probably will cover the first slot but if you want to add another two sticks down the road, they do make low profile RAM.
So I am about to buy a new PC. Inside i will have I7 6700K. So I need a cooler too. I was thinking about be quiet! Dark rock 3 and said that's looks nice and the price isn't bad.
But when it comes to memory i wonder if I could fit G.Skill Trident Z 16GB kit (2x8GB) under it? Do you know how high the RAM can be for Dark rock 3?
Thx.
https://linustechtips.com/topic/595419-cpu-cooler/
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/595419-cpu-cooler/#findComment-7739078
or you could remove the giant fin from the one you put in the first slot and raise you fan slightly, not like that fin actually does much besides the looks
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/595419-cpu-cooler/#findComment-7739578
