54 minutes ago, tr03adam said:
Hi guys, I'm planning to build a Gaming PC and I wanted to know if an ATX Mobo (Asus Z170 Pro GAMING) can fit in a Midi ATX case (Sharkoon VS3-S.If you don't know what is this case google it.duh.).
Yes it will fit.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/594972-pc-build-help/#findComment-7734287
