GPU driver Problem
Go to solution Solved by mrgooglegeek,
Thats artifacting, try installing the latest drivers and then using MSI afterburner to increase the power limit. If nothing else, try underclocking the memory through Afterburner.
After messing around with some drivers, my gpu started doing things Like this: (insert attachment photo). What should I do? I probably fixed it temporarily by installing the drivers from the cd, though the new one wont seem to behave correctly. Also, I edited a bit the photo so that you cheeki breekis see my info.
Project "Transcend": i7 7700k-R9 380 4GB by MSi, Z170-HD3P
My Steam Profile (from SteamDB)
  • Worth: $453 ($123 with sales)
  • Games owned: 76
  • Games not played: 40 (53%)
  • Hours on record: 667.0h
https://linustechtips.com/topic/594915-gpu-driver-problem/
Just now, Supersahen said:
I had this same problem with my old r9 380, tried so many different versions of drivers and settings and finally just gave up and got it RMA'd.
It stared when I wanted to downgrade to 15.12 because a friend with the same GPU said it worked perfectly/
  • Games owned: 76
https://linustechtips.com/topic/594915-gpu-driver-problem/#findComment-7733502
Yeah, that fixed it. I had done that because I wanted to see the lowest temps I can hit in this card.
  • Games owned: 76
https://linustechtips.com/topic/594915-gpu-driver-problem/#findComment-7733579
