Yes.
And don't put caps at the beginning of every word :)
https://linustechtips.com/topic/59491-i-need-help/#findComment-807359
When the card which is the R9 290X(9970) comes out the prices for previous gen will drop but the ability to buy one will be reduced, i recommend that you get a second hand one as many people will be trying to sell their 7970s.
Listen if you care.
https://linustechtips.com/topic/59491-i-need-help/#findComment-807363
Sorry man
Don't worry about it :P
I was just joking around
https://linustechtips.com/topic/59491-i-need-help/#findComment-807386
