Hi, I'm pretty much new to custom builds, and I chose all the components which requires about 342 watts of estimated power. I was planning on Corsair RM450, a 450 watt power supply. I don't know if the 342 watt is the max or the min, but I'm not sure if I should buy a power supply with more power. Tell me if you want to know what the components are and if I should get a higher wattage. Thanks.
https://linustechtips.com/topic/594803-what-power-supply/
Don't buy an RM yellow unit, very poor value. The Seasonic M12 should be cheaper and be a better unit for the money you pay.
https://linustechtips.com/topic/594803-what-power-supply/#findComment-7732277
Can you provide a link to the store you are able to buy from? Your budget?  And your system specification as well will be helpful
https://linustechtips.com/topic/594803-what-power-supply/#findComment-7732280
7 minutes ago, ItsMinJunLol said:
And my budget is 2000$, where I've used about 1500$ for the components
Oh gosh, grab a Seasonic X-series if you have a budget that high.
https://linustechtips.com/topic/594803-what-power-supply/#findComment-7732291
27 minutes ago, ItsMinJunLol said:
whup, I saw it's 1900$ total so I'm probs going to get the seasonic x 460. I can do with around 10 bux over.
What's the system intended use? You likely could get something better for your money, and you're missing a case.
I overdid with the PSU (it's only $10 more than the 550w model...), but this is something I quickly put together (change it how you see fit or based on other people's input). http://pcpartpicker.com/p/DXHJzy
https://linustechtips.com/topic/594803-what-power-supply/#findComment-7732363
