Hi guys,
I basically want to install GTA V on my SSD (Where it currently is) and then again on my HDD. The reason I want to do this is, I want to have a modded GTA to play in story mode (HDD) and then a regular version of it to play online safely. I currently have a lot of mods, so it isn't so simple to just "delete and reinstall them".
Though I have the rockstar warehouse version of GTA V. I can not figure out for the life of me on how to install in two different locations. I even changed the file name from "Grand Theft Auto V". Though when using the setup tool or even trying to launch GTA V, it makes another "Grand Theft Auto V" folder exactly where it was on my SSD still.
I even tried moving the whole (Copying) folder to my other drive, but the same thing just happens. Was hoping you guys could help me out!
https://linustechtips.com/topic/594751-gta-v-installation-help/
https://www.reddit.com/r/pcgaming/comments/16u7tc/
This might help you but I think this is basically what you did I can't tell since you havent tried the two steam directory folders in one PC but try that out maybe.
Also I wonder why it doesn't work with just copying and pasting it should.
Hope some of this helps
https://linustechtips.com/topic/594751-gta-v-installation-help/#findComment-7731775
