Hi i am trying to build a op 1000$ build and im going with amd cause its cheaper. the 9590 is a bit over powered but i will be upgrading in the future.(MUST HAVE 16 GIGS OF RAM. i am an editor and do alot of stuff at once so make it op as possible <3  so if you do edit this and put an intel processor please tell me a good reason why intel over amd. Thanks -LINK- http://pcpartpicker.com/p/WVrFWZ
https://linustechtips.com/topic/593794-best-1000-build/
12 hours ago, AgileXVII said:
can you edit the list to make it better?
Yeah, sorry for late reply (I got off my computer for the night), http://pcpartpicker.com/p/WttKJx. While about $50 more than your original build, it will perform way better. It has a Skylake i5, an R9 390, a better (but still fully-modular) PSU, and a 280mm radiator.
https://linustechtips.com/topic/593794-best-1000-build/#findComment-7723689
