so i've been using this card for a while now the asus 770 oc ii 2 gb, with games like the division rainbow 6 gta blah blah blah, usually i get a steady 40- 80 FPS how ever i was playing R6 the other day and it was studdering at 16-21 fps i haven't changed the settings i haven't installed anything that would conflict with my speed my 16 GB RAM is still going strong. the only thing i can think of is my MOBO ran in to a surge a few months ago (about 6?) it was repaired and worked fine, i can't tell what the problem is ?
i am getting a 1080 in july but still want to know if i need to fix any other issues first?
PC SPECS
MOBO: Z97-C
CPU: i5 4690 (non k)
RAM: Kingston Hyperx 16GB @ 1600
VID: ASUS 770 OC ii 2 GB
HDD: 2 x 1TB samsung
https://linustechtips.com/topic/593383-frame-drop/
Are you using driver 364.xx or 365.10? If so, DDU it, install 362.00 and try again.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/593383-frame-drop/#findComment-7716999
Download Display Driver Uninstaller and the 362.00 drivers from Nvidia. Run DDU and then install 362.
https://linustechtips.com/topic/593383-frame-drop/#findComment-7717014
