Hi everyone;
I've got a corsair RM-1000W PSU with the officail Corsair sleeved cables:
24-pin: https://www.scan.co.uk/products/corsair-individually-sleeved-rm-ax(i)1200i-860i-760i-atx-24pin-cable-(gen-2)-white
rest: https://www.scan.co.uk/products/corsair-individually-sleeved-psu-dc-cable-kittype-3-(gen-2)-for-axi-ax-hx-rm-txm-white
While I do love these cables, I was wondering if these cable combs would fit the cables I bought: https://www.scan.co.uk/products/cablemod-c-series-basic-cable-comb-kit-cable-tidy-transparent-precision-moulded-abs-plastic-re-usabl
I have no idea what the thickness is or anything like that, I was just hoping the combs would fit the cable sleeves.
Thanks
https://linustechtips.com/topic/592776-cable-mod-compatability/
15 minutes ago, SalmanJunaid said:
-SNIP-
Yes their series of cable combs will work with their cables, just note that only has:
Quote
• 2 x 24 pin Cable Combs – Transparent
• 4 x 8 pin Cable Combs – Transparent
• 2 x 6 pin Cable Combs – Transparent
-Moved to Modding Section-
https://linustechtips.com/topic/592776-cable-mod-compatability/#findComment-7711430
