My friend just got a new computer from IBuyPower, but his computer is freezing pretty frequently, he says it happens when he is either browsing the internet or when he leaves it idle. It has only froze once when we were playing Rust.
Any ideas why this is happening or suggestions to fix this?
https://linustechtips.com/topic/591905-frequent-freezing/
Knowing system components, and OS might help. Check manufacturers sites for driver updates for all system components
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/591905-frequent-freezing/#findComment-7702033
have them run a command prompt as admin and enter DISM.exe /Online /Cleanup-image /Restorehealth       then once that finishes enter sfc /scannow         this ensures there are no file system or disk errors doing it
desktop
HTPC
https://linustechtips.com/topic/591905-frequent-freezing/#findComment-7702063
