I have a problem. I just received my graphics card and it turns out that you should probably inspect the both ends of your 6 cables before you buy something. Anyways, I need two 6-pin cables and only have one 8 to 6+2-pin connector. However, the cable has two 6+2-pin connectors on it. Would I be able to use the single cable or do I need to buy another 6-pin cable?
https://linustechtips.com/topic/591834-6-pin-cable-problem/
Welcome to the Forums!
If you mean a daisy chained cable it won't be an issue:
https://linustechtips.com/topic/591834-6-pin-cable-problem/#findComment-7701125
I used one of those on my GTX 560 and it worked fine without any crashing or performance issues. Just get one of those and it should work. All of the cards that I have bought have had with one in the box, so I would assume that if you got it new, there would be an adapter.
https://linustechtips.com/topic/591834-6-pin-cable-problem/#findComment-7701140
Just now, p3rcussion said:
Wow! LTT community is so alive. Thanks guys, I didn't expect my problem to be solved in 10 minutes! Cool, one more thing. How do I disable Integrated Graphics?
Once you have the GPU installed and have the drivers installed it should do all that along side it.
https://linustechtips.com/topic/591834-6-pin-cable-problem/#findComment-7701159
