Hi Everyone,
I have been having a few issues of late with tempriture results. When playing battlefield 4 or Battlefield Hardline my cpu temp in  HWMonitor will exceed 200 degrees c. it doesnt appear to throttle the cpu in anyway its just a wier problem.
My Specs are
amd fx8320 8 core cpu, with the corsair h55 cooling
im using the nvidia gtx750
16gb ram
with a 256 ultra fast ssd.
in a corsair graphite case.
Is there anything i can do to fix it. or is it time to go back to intel.
https://linustechtips.com/topic/591382-cpu-temp-problems/
Sometimes HWMonitor says that my FX-6300 minimum temp reaches -102°C. I think it's some problem with sensors in the FX CPUs, which HWM fails to read correctly sometimes
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
https://linustechtips.com/topic/591382-cpu-temp-problems/#findComment-7696215
3 minutes ago, Comp Web said:
My cpu temp in  HWMonitor will exceed 200 degrees c.
That's hot. It's an error in the software, Im sure.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/591382-cpu-temp-problems/#findComment-7696219
