new pc Help on build:suggestions?
Solved by Streetguru,
8 minutes ago, Copper885 said:I just want to be Able to play any game up too now at a decent fps and graphic setting. Budget is 600$ roughly.
Is the AMD cpu and that video card that bad?
they have poor per core performance, but it might be alright if you need to stream or record footage.
the 380 is simply faster than the 370 by a good margin, it's also faster than the 950/960
