Bottlenecking issues.
Go to solution Solved by KearneyMC,
41 minutes ago, KooKooMan117 said:
MB? i have an am1 socket board. and what would the total be on amazon?
Well the cpu is $ 86.15
So that leaves you to like 70$ for a mobo
OR
AMD Fx-6300- $98.95
MOBO-Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard GA-78LMT-USB3
http://www.amazon.com/AMD-FD6300WMHKBOX-FX-6300-6-Core-Processor/dp/B009O7YORK/ref=sr_1_1?s=pc&ie=UTF8&qid=1462215254&sr=1-1&keywords=Amd+fx
http://www.amazon.com/Gigabyte-DDR3-Micro-Motherboard-GA-78LMT-USB3/dp/B009FC3YJ8/ref=sr_1_1?ie=UTF8&qid=1462215260&sr=8-1&keywords=Am3%2B+mobo
i Recently upgraded to a gtx 950 from a gtx 650 ti, But my fps in BF4 is roughly the same, i have an amd 5350, (quad core 2.04ghz, a am1 socket board) I have 4x2 (8gb 2 sticks of 4) of ddr3 ram and an atx case. Im curious on what motherboard and CPU combo (amd cause its cheaper) I can get for under $150 to be able to run bf4 at its potential with my 950. Any response is appreciated.
Edited by KooKooMan117
Rewording
https://linustechtips.com/topic/590427-bottlenecking-issues/
3 minutes ago, KooKooMan117 said:
i Recently upgraded to a gtx 950 from a gtx 650 ti, But my fps in BF4 is roughly the same, i have an amd 5350, (quad core 2.04ghz) I have 4x2 of ddr3 ram and an atx case. Im curious on what motherboard and CPU (amd cause its cheaper) i can get for under $150 to be able to run bf4 at its potential. Any response is appreciated.
Athlon 860k
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/590427-bottlenecking-issues/#findComment-7684982
25 minutes ago, KooKooMan117 said:
i Recently upgraded to a gtx 950 from a gtx 650 ti, But my fps in BF4 is roughly the same, i have an amd 5350, (quad core 2.04ghz, a am1 socket board) I have 4x2 of ddr3 ram and an atx case. Im curious on what motherboard and CPU (amd cause its cheaper) i can get for under $150 to be able to run bf4 at its potential. Any response is appreciated.
You have 8GB of RAM? 4 x 2GB cards?
ASRock B550M PG RIPTIDE       Corsair Vengeance 16 GB DDR4             TEAMGROUP MP33 1 TB NVME SSD
AMD Ryzen 5 5600X                   Antec DF700 Case                                 MSI Radeon RX 580 4 GB ARMOR OC
https://linustechtips.com/topic/590427-bottlenecking-issues/#findComment-7685112
OR
AMD Fx-6300- $98.95
  • Case: NXZT S340
  • PSU: EVGA 650G
https://linustechtips.com/topic/590427-bottlenecking-issues/#findComment-7685275
