Hey, I am looking to upgrade my monitors in the coming months, and figured I'd go for gold and get three 4k Monitors for my setup. I currently have a GTX 980 Ti and plan to use three Dell P2415Q's over Displayport. My graphics card does have three Displayport outs, but I read online about some cards not being able to support more than two without an active cable adapter for the third monitor. Can anyone give me some insight as to what I'd need to be able to run these monitors with this graphics card?
I'm also not 100% sold on the monitor, but it's the only one I found that has:
  • A 10-bit panel
  • 24 inch screen size or less
  • IPS Panel
If you have any other suggestions for monitors that fit that bill and would recommend over this one, I'm willing to listen.
Thanks in advance.
https://linustechtips.com/topic/589302-3-display-port-monitors-with-a-980-ti/
3 hours ago, SFLPDaidis said:
Thanks for the heads up on that, I guess I'll look for a different monitor in that case.
You can use it, it will just be 8 bit.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Yeah, I read the reviews on Amazon more closely and saw that the majority of them are using standard Desktop cards. I might search around for other similarly sized 4k Monitors, but I would really like to figure out if it's even viable on my graphics card due to my question above.
You should be able to daisy chain them together if you cannot directly output them from the GPU, however you should be fine with it
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
