Help someone is DDOSing me!
By
sjoerd108
in Troubleshooting
in Troubleshooting
Solved by Bittenfleax,
3 minutes ago, sjoerd108 said:Resetting my router won't reset my IP just gave it a try.
Oh, then you're out of luck. The only other thing is to turn it off for a few hours and see if that does anything (doubt it will, but it may be an exception). If not, you may have to buy a host. However, they are fairly cheap.
denizayciceks ·
Posted in Troubleshooting7 -
4
Macaw ·
Posted in Console Gaming5 -
4
2
Shahrad ·
Posted in LTT Releases8 -
9
