Hello everyone,
This is the first time I using LTT forums and I have a question about crossfiring my R7 265. I would like to know if I could crossfire my card with R7 370 and if yes if I need a bridge. The reason why I'm asking this, is because the R7 265 is actually pricier than the R7 370 even used. Thank you and have a great day.
https://linustechtips.com/topic/588778-r7-265-crossfire-help/
No, only AMD GPUs with the same core can CrossFire, like a 270X and 370X could but not a 380 and 390.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667526
They have the same core, pitcarin. The 270x and the 7870 have 1280 cores and the 7850, 265, and 370(x) all have 1024 cores. They can ll run in crossfire.
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667566
They do? My bad I thought the 265 used Bonaire like the 260(X). It has been a while since I have had to do anything with those cards.
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667573
So I can crossfire my card with r7 370 and which cards?
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667577
265 can crossfire with any of these
7850
7870
265
270
270x
370
370x
You will also need a crossfire bridge because these cards are GCN 1.0
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667600
7850
7870
265
270
270x
370
370x
Is this bridge legit?
https://www.amazon.ca/CrossFire-Electronic-Bridge-Computer-Connecctor/dp/B0183P1ZUM/ref=sr_1_1?ie=UTF8&qid=1461894077&sr=8-1&keywords=crossfire+bridge
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7667900
3 hours ago, Kbesnier3 said:
Yeah it seems like it, I don't see why anyone would ever try to sell fake CrossFire bridges anyway.
https://linustechtips.com/topic/588778-r7-265-crossfire-help/#findComment-7668576
