Hi, I'm trying to decide between two builds and I would definetly appreciate help. I would mostly use pc for gaming so I want to make sure that I could play The witcher 3 on high settings with about 50 fps as well as some upcoming games lik Deus ex: Mankind divided or Mass effect Andromeda...
This are the builds:
CPU: Intel i5 4460 3.4GHz Soc.1150                                            CPU: AMD X6 FX6300, 3.5GHz
Motherboard: B85 Soc.1150                                                      Motherboard:   Asrock 980DE3 U3S3
GPU: AMD Radeon R9 380X 4GB DDR5                                      GPU:  Gigabyte GTX 960 4GB DDR5
RAM: 8GB DDRIII        RAM:  8GB (1*8GB) DDR3 1600MHz
SSD 240GB        Toshiba 1000GB 7.200o/min High-Performance
Case: MSI RAIDER Front USB 3.0                                                 Case: Zalman Z1
PSU: Gigabyte 650W 80 Plus Bronze                                             PSU: Fortron Hyper 500W, 80+
Sound: 7.1 channel audio                                                             Cooling:  LC-CC-95, 90mm, PWM
https://linustechtips.com/topic/588655-need-help-with-pc-build/
left one way better in every way. whats your budget?
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/588655-need-help-with-pc-build/#findComment-7666127
Left side.
Would you like any other suggestions?
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/588655-need-help-with-pc-build/#findComment-7666176
