EFI Shell Version 2.31 [4.655] .... problem
Does it boot into windows after that? I dont think so ...otherwise you wouldnt have asked....me dumb
anyway...what does pressing esc do?
If that does nothing, then get into BIOS and see if your harddrive / SSD is recognised.
If it is and the same problem persists, come back here?
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
Next I would suggest going into the BIOS and selecting "Reset to Optimized Defaults" or whatever your particular motherboard has. Could be "Factory Default Settings".
there is a countdown 5 to 1 if i pressed ecs during the counting it will jump to number 1 directly  and stop and nothing happens.
how can i now if the bios is recognizing my hdd or not ?
I have an MSI motherboard, were can i find this option ?
Go to your BIOS?
By hitting F12 immediateley after you press the power button on your PC....
Did you fool around with any setting on your BIOS? Maybe had a friend overclock the CPU for you?
Resetting to factory defaults will help your computer come back to normal
Go to your BIOS?
i have been trying to find a "rest to default" button for hours :S
A picture of your BIOS?
1 hour ago, MAROON5 said:
solved it By changing the sata cables :D
how did u get the idea?
because i gave up and tried the last option which is reinstalling windows, but unfortunately non of my drives are recognized 9_9 so i think & think & think & remembered that when i changed my power supply (corsair to EVGA) i changed all the cables except the sata cable, so i replaced the "old corsair sata cable" with the "new EVGA sata cable" (the cables that come with the power supply) and it's worked :D.
sorry about my English, i'm trying so hard to improve it :$.
Oh thats great...now i know what to recommend to people when they have this problem ..
  • 7 years later...
