At2020 Setup Help?
Solved by megaant4,
Fair enough, but for for school they don't really expect much in terms of audio quality.. As long as it isn't a potato microphone you'll be right. I never owned the USB AT2020 but I did have the Blue Yeti which worked amazingly. I wouldn't recommend using the PSU as you'll probably have worst quality than the USB version of the mic.. But I'm not entirely sure and if your research says otherwise, then go for it. But I would recommend an audio interface
If you want to start small, the Blue Snowball is also a great option. But you should look around at other mixers, as you can get some really good ones for pretty cheap.
