1 minute ago, Jonathan McCann said:
Its not even a high resolution picture....What am i doing wrong?
Its a download link. ...why dont you just post it in "insert media"?
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/587170-wtf-gmail-help/#findComment-7649207
Safe link. Just dont have a file size bigger than 25mb..
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/587170-wtf-gmail-help/#findComment-7649218
Without being able to see the original file details, I can only guess but based on your screenshot being in .BMP format is it possible that the image you are trying to send is too? BMP is a lossless bitmap file format with absolutely no compression. If you could convert the image to something like .PNG or even .JPG you would see a much smaller file size with the same image.
If that doesn't help, as others have suggested, use a cloud based file service with a large enough capacity to handle the file as Gmail has a limit of 25MB for attachments.
https://linustechtips.com/topic/587170-wtf-gmail-help/#findComment-7649597
