MS Paint help?
1 minute ago, ChickenNugget said:
I copy/pasted a picture into MS Paint and traced over it, but now I need to remove the picture so just the drawing is left. Is that possible? If so, how??
Thank you,
Chicken Nugget
If you can somehow select the picture you can delete it.
but now everybody knows you traced it, you already can't tell people you drew it without criticism. (/jk)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/587124-ms-paint-help/#findComment-7648619
Nope, Paint doesn't support layering at all, if you add a picture then draw over it you drew over it in the same way as if you'd taken a paper copy and drawn over it.
As suggested get GIMP or Paint.net, both are free and much better than Paint.
Main Rig:-
Server:-
https://linustechtips.com/topic/587124-ms-paint-help/#findComment-7649492
i think the point is that he used paint. it has to be paint!!!
Solitaire.
https://linustechtips.com/topic/587124-ms-paint-help/#findComment-7649498
