https://linustechtips.com/topic/586811-water-loop-help/
3 minutes ago, TravisB said:
All right cool, Also would I need this? or just those fittings?
https://www.ekwb.com/shop/ek-hd-adapter-csq-10-12mm-black
The HDC version is the ones you will want as it compresses the top oring onto the walls of the tube to hold it, that version is just a slip fit so it doesn't have a compression ring you can use, mainly used for SLI or crossfire connections between GPU's.
https://linustechtips.com/topic/586811-water-loop-help/#findComment-7645414
