https://linustechtips.com/topic/586565-water-loop-help/
No, those are fittings for soft tubing. If you are going to to hardline PETG you will need:
https://www.ekwb.com/shop/fittings/hard-tubing-connectors/hdc-fittings
or
https://www.ekwb.com/shop/fittings/hard-tubing-connectors/hd-adapters
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/586565-water-loop-help/#findComment-7643280
