So I've had this installed in my system now for over a week, and it just puzzles me how the performance os actually WORSE than my Corsair H100i GTX. The idle temps bounce all over the place from between 25c and 40c, and quickly escalates when under load to 55c. When using the Corsair, it was a stable idle temp at a nice 25-30c and wouldn't jump all over the place, and under load it would be a slow climb to higher temps. I just do not get whats wrong at all...How tight am i suppose to screw the cpu block down? Until they're tight? They use springs under the screws.. Is there something else i might've done wrong?
I am aware that my pump is facing the wrong way, but it wont fit anywhere else in the Corsair 400c, and it doesnt look that bad (the white sticker has already been removed, no worries)
My Build:
Processor: Intel Core i5 4590 @ 3.3ghz
Motherboard: ASRock Z97 Fatal1ty Killer
Graphics: Sapphite Nitro+ OC RX 480 8GB
Memory: 8gb Kingston HyperX Fury 1866mhz RAM (2x4gb)
Cooling: Swiftech H220-X2
Case: NZXT S340 Elite Tempered Glass
Power Supply: EVGA GS650 650W
Lighting: NZXT Hue+
Extensions: Phanteks Black/Red Extensions
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/
2 minutes ago, FilipSebik said:
Bad mount? Try remounting it
Yea i tried that already, even reapplied thermal paste too :c
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/#findComment-7643041
Just now, FilipSebik said:
Stupid question but is your pump plugged in?
completely understandable, but yes its plugged in haha
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/#findComment-7643046
Try making it run at full speed to hear if there are any bubbles in pump that may be restricting the flow of the pump
Now sure how i would do that exactly. The pump is connected to the power supply. The only thing i have control of is the fans (AFAIK).
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/#findComment-7643055
I've got just a cheap phone so potato quality, but i use my paint skills.
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/#findComment-7643085
I don't have a clue
Alright well thanks anyway. Im sure i just missed something somewhere
If anyone else has any input that'd be great ;D
My Build:
Lighting: NZXT Hue+
https://linustechtips.com/topic/586525-swiftech-h220-x2-issues/#findComment-7643103
  • 3 months later...
