4 hours ago, Memorizer said:
Check the height of the desired CPU Cooler then check your desired Case's width. Or at least check the specs and the dimensions of the parts to see if they fit.
Case width doesn't always give close to correct result. And if you'd bothered to look, it doesn't say anything about that on Raidmax product page either.
Case can fit 165mm coolers. So D14 will fit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/585811-guys-please-help/#findComment-7638556
