Im needing a power supply (preferably not over 60 pound (can go slightly over)).
It needs to either be modular or have fully sleeved cables,
Be a good brand and not blow up,
Have good cable options but not excessive,
2X 6pin power cables (not essential but would be nice)
Thanks for the help!
https://linustechtips.com/topic/585331-best-600w-power-supply/
25 minutes ago, Moonzy said:
something like this?
http://uk.pcpartpicker.com/part/xfx-power-supply-p1600bxtfr
what are you trying to power anyway
XFX XT series are as bad as the CX series.
2 minutes ago, Hegehog said:
Amd fx8350, r9 380 and maybe another r9380 down the road.
Thanks for the reply BTW
The 8350 will seriously bottleneck anything over the 380 without some serious overclock, and cross firing or sli-ing is usually not recommended.
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632054
3 minutes ago, Hegehog said:
ok thanks. So is the xfx series not good then?
Not that one, the XT is not so good.
http://uk.pcpartpicker.com/part/seasonic-power-supply-ss620gm2
http://uk.pcpartpicker.com/part/xfx-power-supply-p1650gts3x
http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632088
Just now, Hegehog said:
Im replacing my pile of crap iMac, I have an AMD motherboard. Im buying amd x8350 and an r9 380 (for the main things). It will be for gaming and video editing if that means anything.
What´s your overall budget? Can you return the motherboard?
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632144
my overall budget is unknown but it is around 550 GBP. The motherboard I could sell as I bought it used for a steal.
If that´s the maximum of your budget, that´s a pretty much as good as you´re going to get. Just get a decent cooler and overclock the shit out of your 8350, you won´t find anything a good experience unless you do so.
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632176
Im planning on overclocking it to hell. One last question for you si the hyper 212 eve any good for overclocks or is there a batter one for sub ~£50
The H7 would be better than the 212, but neither would be able to let you oc to hell. The H55 would do better as a water cooler, but still wouldn´t allow anything too crazy.
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632212
Need RAM?
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (£222.04 @ CCL Computers)
Motherboard: Gigabyte GA-Z97-D3H ATX LGA1150 Motherboard  (£54.99 @ Ebuyer)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  (£60.92 @ More Computers)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  (£159.98 @ Novatech)
Power Supply: SeaSonic EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£69.95 @ CCL Computers)
Total: £567.88
Generated by PCPartPicker 2016-04-21 22:26 BST+0100
This would be a better option.  The Xeon is better when gaming, and in highly threaded applications.
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632220
This would work better:
PCPartPicker part list: http://uk.pcpartpicker.com/p/CjTmdC
Price breakdown by merchant: http://uk.pcpartpicker.com/p/CjTmdC/by_merchant/
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor  (£205.80 @ Amazon UK)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  (£50.44 @ CCL Computers)
Memory: Kingston HyperX Fury Red 16GB (2 x 8GB) DDR3-1866 Memory  (£50.93 @ More Computers)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Total: £538.12
Generated by PCPartPicker 2016-04-21 22:24 BST+0100
https://linustechtips.com/topic/585331-best-600w-power-supply/#findComment-7632236
