im assuming you're re-using DDR3 since you never listed ram
i would get a higher capacity hard disk
an SSD is optional but preferred, one can be added later though
maybe swapping the GTX 960 to an R9 380 4Gb version, unless you need nvidia's features
swap the psu for something more reliable, like the EVGA's B2 750W, its pretty cheap now iirc, even though the wattage is overkill
or a seasonic S12ii 520W
also, you can get windows cheaper from other sources like G2A or kinguin or subreddit microsoftsoftwareswap
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/584832-project-first-buildup/#findComment-7626532
I have an ssd pny 480 GB now with hdd
https://linustechtips.com/topic/584832-project-first-buildup/#findComment-7626987
