Hey so ive got zero experiance overclocking and im looking to pop my cherry with my Sabertooth Z77 and 3570k, I recently had a friend overclock it to 4.2GHz however i had to reset it due to high temperatures from a bad cooler mount. Any help would be greatly appreciated
https://linustechtips.com/topic/583560-sabertooth-z77-overclocking-help-needed/
Aight, so you pop into your bios and bump up your core clock multiplier. Set it back to 42, and see how it goes. If it crashes, give it a few hundredths of a volt until it's stable. If you can't get it stable and within a temperature you're comfortable with, turn the multiplier down and the voltage as well and continue tuning.
ASU
Thanks man ill give it a quick try
