LED Lights for PC.
Solved by W-L,
1 minute ago, TheNaitsyrk said:These are actualyl quite expensive. I need 4 of them, but £17 each is way too much to pay for looks. I was aiming more towards £6-8 price range.
In general you wouldn't need 4 of them usually 2 are good to provide even lighting, they also have longer 60cm strips if you really want the lights to wrap around, so you wouldn't need to get 4 separate kits.
