before anyone says about me picking a CX psu for a gaming build I originally had just a 4690k and wasn't going to buy a high end GPU but decided to buy a 970 as I gamed more on my pc then my xbox one
so my CX600 is making an electrical cracking sound, I instantly shut of my pc, I pulled everything out and jumped the pins on the psu to start it up and it still makes that sound so I know its the psu. its over a year old now so I don't think they still warranty it? but I might be wrong
My speakers dont even fit on or under my desk...PA's FTW
https://linustechtips.com/topic/582253-psu-eletrical-cracking-sound/
That crackling sound is called coil whine. I bet you have an EVGA 970!
I have (pretty much) the same setup and I believe that it's the 970 that's producing the coil whine, not the PSU. I had a 750Ti before upgrading it to a 970 and there was none. It's that that's causing it and there's no way to prevent it.
Sorry, bud.
I say jiggly-bytes when I see "GB".
It goes down better than you would expect.
Sorry, bud.
its the psu, I pulled the psu out and jumped the pins and it started to make the crackling sound
BTW I have a strix 970
