Need help with build.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£224.99 @ Amazon UK)
Motherboard: ASRock Z170M-ITX/ac Mini ITX LGA1151 Motherboard (£105.50 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (1 x 16GB) DDR4-2666 Memory (£89.69 @ Amazon UK)
Storage: Intel 535 Series 240GB 2.5" Solid State Drive (£63.91 @ Amazon UK)
Video Card: Sapphire Radeon R9 Nano 4GB Video Card (£412.72 @ Amazon UK)
Total: £896.81
Generated by PCPartPicker 2016-04-15 11:39 BST+0100
a 1TB ssd is overkill to the extreme. use the ssd as the boot drive and to hold your essential apps/slow-loading games, keep the rest in the hdd. for cloning, you can put any unnecessary files onto another storage device until there is less than 200gb, then you clone the rest to the ssd, or just do a fresh install.
