Good Micro-ATX small case?
Go to solution Solved by Joe4096,
How about the Corsair 350D?
 I want a Micro-ATX case for a HTPC, I need a DVD drive expansion bay and at least 2 3.5" HDD bays. As this is a low power system and an old pc I have a GT 610 which can be fitted into small form factor cases and it needs to have normal atx PSU support, Its a tough one i know. If you have any suggestions add them below and i will cehck them out! thanks for reading!.
https://linustechtips.com/topic/581941-good-micro-atx-small-case/
