Cpu Blade and Soul.
Go to solution Solved by Moonzy,
7 hours ago, Sporadic said:
THankyou. took me 50m to figure out how the quote thing works haha
This is what i have placed together so far. May i ask your opinons?
 AndThankyou! For all the information :)
if possible, use pcpartpicker.com next time :P its easier and you wont miss a few parts
comments
1) you probably dont need aftermarket thermal compound, i recommend using whatever comes with your cpu cooler first, save some $$
2) you're lacking a cpu cooler, the 6600k doesnt come with one in the box
3) dont get the V300 ssd, it has issues, more on this here, i recommend getting the 850 evo instead, pricier but is much more reliable
4) lots of parts missing, like case and psu, gpu and cpu cooler :P
5) might wanna add an gpu, unless you're fine using the iGPU for now
Hello.
I'm currently trying to upgrade my computer to play a game named. Blade and soul
This game is highly Cpu dependent and only works on a single core,
Well watching endless videos and reading forums i just don't understand
what would be a good cpu for the game if cores does not matter. (I know more would be better for back ground programs)
And after reading endless postes and bios between AMD and Intel I'm simple more confused,
I have around 700$Canadian for a motherboard/cpu
https://linustechtips.com/topic/581865-cpu-blade-and-soul/
No AMD CPUs, it's fine but not as good as Intel in B&S. I own an AMD CPU and played the game.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7597193
welcome to the forums! :P
remember to quote or mention the person you're replying so they get a notification ;)
then i highly suggest going with skylake, it has the best single threaded performance now
for games, single threaded performance are often more important than having more cores
because games normally run on less than 4 cores, so having extra cores would be just having those extra cores sitting there doing nothing
thus having faster single core would yield better gaming performance
though DX12 is supposed to increase multithreaded performance in gaming, but we'll have to wait and see
for now, intel skylake has the best gaming performance for mid-range to high end products
AMD are the typical go to for budget around an i3 system, depending on what you do
this is because AMD have yet to renew their cpu lineup in a while, and AMD Zen is coming soon ;)
what about ram? skylake supports DDR4 or DDR3L
if you wanna use your existing DDR3, haswell are great as well, not much performance difference compared to skylake
23 minutes ago, Sporadic said:
CPU: AMD FX-8350, Same one i was looking at, And
CPU INTEL|CORE I5 4690K 3.5G 6M R Configurator
But all the tests i'm finding are one entire cpu and idk how strong the cores are individually
https://www.cpubenchmark.net/cpu.php?cpu=AMD+FX-8350+Eight-Core
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i5-4690K+%40+3.50GHz
1504 vs 2223 for single core, the i5 beats the amd chip
both are unlocked so they can be overclocked further and the gap will widen :P
the i5 should overclock further if you have a moderate cooler, since it has a lower tdp
but as always, OC depends on your luck
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7597321
Intel Core i5-6600K 6M Skylake Quad-Core 3.5 GHz LGA 1151 91W
Arctic Silver 5 high Density Polysynthetic Silver Thermal Compund AS5-3.5G - OEM)
CORSAIR Vengeance LPX 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000)
WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
Kingston SSDNow V300 Series 2.5" 120GB SATA III Internal Solid State Drive  -Two
GIGABYTE G1 Gaming GA-Z170MX-Gaming 5 LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 Micro ATX Intel Motherboard
Wide awake but brain is dead. Now i know how my computer feels lol,
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7599089
comments
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7600136
Think i owe you coffee big time.
Quote
Hopefully i did it correctly this time, Also im trying to upgrade my computer Not build a new one. BUT! Its not working out that way lol.
Newegg bundle :P lol
  • 1 × Intel Core i5-6600K 6M Skylake Quad-Core 3.5 GHz LGA 1151 91W BX80662I56600K Desktop Processor Intel HD Graphics 530
  • 1 × ASUS Z170 PRO GAMING LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
    2 × CORSAIR Vengeance LPX 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 2133 (PC4 17000) Desktop Memory Model CMK8GX4M2A2133C13
  • 1 × WD Blue 1TB Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZEX - OEM
    1x SAMSUNG 850 EVO 2.5" 120GB SATA III 3-D Vertical Internal Solid State Drive (SSD) MZ-75E120B/AM 1x
    Sad. Need a new watercooler cant get 2 lol.
    1x DEEPCOOL Gamer Storm CAPTAIN 120 CPU Liquid Cooler AIO Water Cooling Ceramic Bearing Pump Visual Liquid Flow with 120mm FDB PWM Fan Rubber Coating Deep Silent Support LGA 2011-v3. Intel LGA 1150 / LGA1151 / 1155 / 1156 All Series
    Rosewill RTK-045 45 Piece Premium Computer Tool KiT
    Startech M3013 24x26in Grey Desktop Anti-Static Mat.
    Owned~
    -Cooler MASTER SILENT PRO GOLD 1000W,
    - Evga Geforce Gtx 680
    -Cooler Master HAF X - High Air Flow Full Tower Computer Case with Windowed Side Panel and USB 3.0 Ports
    Grand Total: $1,014.27
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7603832
comments
  Hide contents
Quote
    Owned~
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7603889
get an air cooler or a 240mm water cooler,
single 120mm or 140mm rads arent that great, better off with an air cooler lol
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7604555
Thankyou!!!!!!      Because of your advice i got threw this with sanity to spare lol so great full, I'm also sorry i have asked so much!!! Guess thats why your name Moonzy, inspiration to people like me looking at the Sky for hope haha,  Would offer coffee money or something but broke now ha,  If you ever play blade and soul, Just ask I'll Fuel you with supplies Haha...  Sporad (Alt 141 )c /  Sporadìc Igm,
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7604744
lol i might play BnS one day :P
since lots of my DN friends went to it lol
https://linustechtips.com/topic/581865-cpu-blade-and-soul/#findComment-7604752
