16 minutes ago, harrowx said:
I'm getting a new air cooler for my computer and I would like to know if which company you buy cooling compound from matters
Just get whatever has good reviews within your budget. Arctic Silver is one of the well-known ones, but performance between entry and high-end is within a few degrees of each other.
i7-4790K | Gigabyte G1 Gaming GTX 970 | G.Skill Ripjaws X Series 16GB (2 x 8GB)
Gigabyte GA-Z97MX-Gaming 5 | Corsair 350D | 256GB Crucial MX100 / 1TB WD Blue | Corsair RM 650 | NH-U12S
http://pcpartpicker.com/p/9XN2dC | http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Deil_Grist
Also, many coolers come with a small tube of paste or with paste pre-applied. Check the product information before you run out and buy some (though you'll need to re-apply at sometime, I guarantee it, so buying some now might save you frustration during the build if you smudge what it comes with).
