I doubt theres much in it you should turn off thats not inconvenient. You can go into the startup program folder (somewhere in appdata/windows/startmenu/startup or something like that) and take out the shortcuts/links or you can use a 3rd party tool.
What cpu/hdd and whats the boot time?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/581486-start-up/#findComment-7593391
Ooooor go in task manager and go to the start up tab :P
Well, now you're reading this, I might as well inspire you with a deep quote
If you fall, I'll be there
             - Floor
so inspiring, so deep, the feels ;-;  THE FEELS ;-;
Newer Build which I'm gonna buy when I haz moneyz
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£0.00)
CPU Cooler: be quiet! PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  (£25.98 @ Novatech)
Motherboard: MSI B85-G43 GAMING ATX LGA1150 Motherboard  (£78.10 @ Amazon UK)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£0.00)
Memory: Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1600 Memory  (£29.76 @ Ebuyer)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£0.00)
Video Card: MSI Radeon R9 380 4GB Video Card  (£179.99 @ Amazon UK)
Case: Corsair 780T ATX Full Tower Case  (£149.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£70.97 @ Amazon UK)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For £0.00)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£59.00 @ Amazon UK)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  (£24.99 @ Amazon UK)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  (£184.99 @ Amazon UK)
Total: £803.77
somethings says '£0.00' because I already bought them
probably best remix out there
If I follow you, consider your self lucky, I rarely follow people and when I do it's either because
1) I look up to you
2)I like your picture
3) Or you have an epic ass rig (40 titan x's 9 6700k's clocked at 29GHz that is what I call a epic ass rig, but no one has that soo...)
https://linustechtips.com/topic/581486-start-up/#findComment-7593410
I haven't actually messed with win 10 task manager much @LynxThe1st,my main pc is on win7 which I don't believe has that. But yes, if its an option try that @xwrench3
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/581486-start-up/#findComment-7593451
thanks! its been a long couple of days. but moreover, my brain is about 1/2 fried. i have second stage CRS! LOL.
i have not actually measured boot time. i just knew that i screwed up on installation and did not remove the start up check from the box when i installed them. this is a new system, intel i5 6500, 16gb ram, 1tb wd blue. its pretty quick, especially compared to the old tank i was using. i could play 3 games of solitaire before it finally booted up! i just want this to be fast as possible. until Christmas. i will get a small ssd then for a boot drive.
https://linustechtips.com/topic/581486-start-up/#findComment-7593468
On April 14, 2016 at 8:14 AM, EBLITZR said:
Yup, used to be in 'MSconfig' But moved to the task manager some time ago...
It's moved to task manager since windows 8. Clean install Windows 10 is you've upgraded to windows 10, that way it would create less problem in the future
https://linustechtips.com/topic/581486-start-up/#findComment-7598937
