I am friends with the owner of a local hookah join who wants to change from displaying Cable Television to using a Raspberry Pi. He has a Roku set up to one tv and I'm guessing a box with all the cords running to each tv. Is there a way to hook up a Raspberry Pi the same way. I can get more info when I go there soon. But that's what I've seen from the basic set up.
https://linustechtips.com/topic/581373-raspberry-pi-multi-display-set-up/
If you are meaning to use a hdmi splitter to  display the same signal from th RPi on multiple screens from a single hdmi input then it should work. Make sure that the splitter doesn't need power from the RPi, or that the splitter is powered though because the RPi  doesn't supply much power.
Edited by SLAYR
Grammar
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
How many TVs are there, and are they all hooked up through HDMI? You might want something a bit more powerful than a Pi.
10 minutes ago, CaptDrakeGrace said:
There are 5 tvs and they are hooked up with Coaxial Cable
So wait what exactly is the goal, just to hook them all up to a central PC?
Is there already like a splitter sending the signal to all the TVs like below? not sure if that's how it works exactly.
Probably would need a powered splitter I guess like this, 8 way one here, not sure what bi-directional means exactly
http://www.amazon.com/Bi-Directional-Amplifier-Splitter-Booster-Passive/dp/B000WDR94U/ref=sr_1_6?s=audio-video-accessories&ie=UTF8&qid=1460574251&sr=1-6&keywords=Coax+Splitter
