I have this old hp pc and I need to retrieve some files of it but it wont boot.
I have tested the PSU and it is all fine (green light also lighted up) I have tried it without ram sata ports using a screw driver to boot
if you know any way please share because I need these files fast
if it helps here is model number: HP PAVILION SLIMLINE S3020.NL
EDIT: The files are somehow locked and can only be retrieved by that pc
EDIT: Specs:
CPU: Xeon e5450 (LGA 775 Modded)
Ram: 3GB of some random generic brand
GPU: Nvidia GT630
PSU: ACBEL HP STOCK PSU (HP Part Number: 5188-7521)
Red ​White ​Blue
https://linustechtips.com/topic/580203-help-pc-not-starting/
Take out the harddrive from that machine and put it in your main rig?
[GUIDE] LGA 771 Mod for Dell Vostro 220 [GUIDE] LGA 775 BSEL Mod [BUILD] The Mighty Radeon-Powered Dell [VIDEO] Evolution of Intel CPUs
Can you game on an 8-year-old i7? Is the 4-year-old GTX 660 still relevant? Upgrading the HP Pro 3500
Main Rig:
CPU Intel Core i7 4930k @ 4.3GHz | Motherboard ASUS P9X79 Deluxe | RAM Hynix 32GB (8x4GB) 2133MHz CL11 | GPU Gigabyte GTX 980Ti G1 Gaming | Case NZXT Phantom 410 | Storage Samsung 850EVO 500GB, Seagate Barracuda 2TB | PSU Cooler Master G650M (650W) | Monitors x1 Dell U2515H, x2 Dell 1907FP | Cooling Noctua NH-D14 w. x2 NF-F12 iPPC-2000 PWM | Keyboard Logitech G610 ORION BROWN | Mouse Logitech Performance MX | OS Microsoft Windows 10 Pro x64
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580636
Just now, Seabosz said:
its locked some how I already tried
Ah ok.
Main Rig:
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580642
5 minutes ago, ronstig said:
What do you mean 'locked'? Can you provide a more detailed explanation of what happens when you try to use it on another PC.
it says the drive need a BIOS master key to unlock
(I have litterly never heared of this my entire life)
Red ​White ​Blue
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580689
means that desktop encrpts data that goes into the hard disk
gg for you
try contacting HP, maybe they can help you get your files
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580713
gg for you
but is there any way to make that desktop work (iam not in the mood to talk to some shitty customer service)
Red ​White ​Blue
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580742
what you can do is try replacing the parts in the case 1 by 1, ram, psu, gpu or what not
see if the motherboard posts `-`
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580748
iam only noticing now but there is a weird sound coming form the psu when plug It in but its only noticible when I hold my ear near it
Red ​White ​Blue
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580822
replace the psu and try it out then `-`
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7580844
22 hours ago, Seabosz said:
ok Thanks anyways ill see what hp has to say and then ill let you guys know
Ok, So I Looked online for a replacement psu and I see that they cost about 120 euros wich iam not going to pay for that mayby there are some adapters somewhere on the internet but thanks for helping anyways! :D
Red ​White ​Blue
https://linustechtips.com/topic/580203-help-pc-not-starting/#findComment-7585871
