Is this a good pc for CS:GO,Black ops,Fallout 4
61921421e30d92bf7518f831d3a5de78.med.256 £80.25       £80.25 Amazon UK   Buy
CPU Cooler ddea57de9797549e80d05fb3acb2e83d.med.256 £26.99       £26.99 Novatech   Buy
Thermal Compound a2221e7d5925c28e97b9b63516b1288b.med.256 £6.19   £2.28   £8.47 Overclockers.co.uk   Buy
Motherboard 49a6ee7fbae908540c4e353616f4c6bc.med.256 £49.24   FREE   £49.24 More Computers   Buy
Memory b46a7bcfa004c691eab3bb54a1f57e0a.256p.jp £15.56   Free two-day shipping with Amazon Prime   £15.56 Amazon UK   Buy
  Add Additional Memory
Storage 381207fcd3c13610d787357c9cae8627.256p.jp £37.98       £37.98 Novatech   Buy
  Add Additional Storage
Video Card 8db8d544f6ceb36a5531ce83d9aaeb2f.256p.jp £119.99   Free two-day shipping with Amazon Prime   £119.99 Amazon UK   Buy
Case 908885ac9326cfbd3462255bd98b326a.256p.jp £28.99       £28.99 Novatech   Buy
Power Supply 0a13919fa78b3f3940683aed1d4cd0ac.med.256 £26.99       £26.99 Novatech   Buy
Optical Drive c5a6c2fe2deb45a3a72e1d3f2aa3bb51.med.256 £12.48       £12.48 Ebuyer   Buy
  Add Another Optical Drive
Operating System   £72.22   FREE   £72.22 More Computers   Buy
Software   Choose Software
Wireless Network Adapter bbbdd027ae45d5142f7cc2995b628c2f.med.256 £29.10   Free two-day shipping with Amazon Prime   £29.10 Amazon UK   Buy
CPU: i9-9900k
Motherboard: MSI Carbon Pro AC
Memory: GSkill Trident Z Royal Silver 32gb
Storage: SanDisk - Ultra II 480GB 2.5" Solid State Drive
Storage: Western Digital - Blue 4TB 3.5" 5400RPM Hard Drive
Video Card: ASUS Strix GTX 1050ti 4GB
Case: Corsair - Vengeance C70 (Black) ATX Mid Tower Case
https://linustechtips.com/topic/580193-build-for-friend/
CPU: i9-9900k
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580522
What´s your total budget?
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580531
Around £500
CPU: i9-9900k
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580535
3 minutes ago, Tech N Gamer said:
Questions, is your friend going to use WiFi and use DVD's? And personally, I'd use a WD Black, but that's because I don't have good experiences with seagate.
Yes he will use CDs and Wifi
CPU: i9-9900k
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580541
That power supply is not that great, get something better from here:
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580560
At 1080p, that 2gb 950 should keep you above 40 fps at medium-ish graphics.
I might look at getting a different PSU, though. Something Seasonic or XfX.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580576
comments:
1) you dont need that thermal paste, the hyper 212 comes with a tube if im not mistaken, save some cash
2) buy dual channel ram kit instead of two individual ram sticks, its better
3) wd blue instead of barracuda all the way lol
4) 950 is fine, but i would personally up it to 380 4g or 960 4g, most likely 380 for better DX11 and DX12 performance
5) not a great psu, change it pl0x
6) get windows cheaper from subreddit microsoftsoftwareswap
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580606
Also the FX 6300 is getting pretty old, so may want to consider getting the i3 6100.
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580620
Antec EarthWatts Green 380W 80+ Bronze Certified ATX Power Supply
CPU: i9-9900k
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580674
is this any better
CPU: i9-9900k
https://linustechtips.com/topic/580193-build-for-friend/#findComment-7580677
