Hey guys, I was wondering if I could get some advice as to how I should
approach my computer science assignment.  I'm supposed to design a
program that helps people through airports. Basically I'm supposed to have
a linear linked of the time required to be processed at each of the major
airports.This information needs to come from an external data file that I
create called airport.txt. Each airport has to have the following:
-number of checkpoints
-time though each checkpoint
-Size of the airport
And then I'm supposed to have an array of linear linked lists that is a
travelers itinerary. Each linear linked list is supposed to be a route from
point A to point B.  The first node is supposed to hold the travelers info
such as customs/immigration. The rest is the stops to the final destination.
The next LLL in the array is supposed to hold the rest of the trip for the way
back.  My main issue with the program is that I can't prompt or read in
anything from my class member functions and it has to be done from main.
So with the information given could someone give me some tips for how I
should structure my program and have it pass stuff from main to the functions.
Thanks in advance for any tips.
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/579854-c-program-structuring-help/
2 hours ago, Gachr said:
I got kinda lost there, but I'm worried about one thing...
How are you going to store all that data inside .txt format? I understand YAML or CSV, but it will be quite difficult to parse pure .txt files.
I have no clue, my professors technical documentation is always extremely vague as to what they actually want.
