Powerline Adapter problems
Go to solution Solved by alexyousef,
I got it working now
Hey Forum,
Recently i purchased n On Networks 200Mbps Powerline Adapter.
http://www.amazon.co.uk/On-Networks-200Mbps-Powerline-Adapters/dp/B008O52VN2/ref=cm_cr_pr_product_top
However I am getting terrible speeds despite my electrical system being renovated this year.
Powerline
Wi-fi
post-6249-0-26933600-1379618357_thumb.jp
https://linustechtips.com/topic/57984-powerline-adapter-problems/
I would try the units on different power points in the same room and see what result you get. Also, make sure you pair them in the same room as well, and then move them to where you want (just easier). I have powerline adapters in my house, and they are brilliant, but they got to be setup correctly from the start. Reset the units as well before you pair them (I hold the button down for 10 seconds when resetting mine)
https://linustechtips.com/topic/57984-powerline-adapter-problems/#findComment-786193
