Hi everyone.
I just got a new GPU and swapped the old one out and put in the new..
Now my ASUS Maximus VII GENE is not posting and appears to be rebooting over and over.
I've tried swapping back to the old card with no difference.
It powers on, and i can see the Q-Code display showing a lot of numbers, it shows a Q-Code 15 followed by a 00 and then starts over.
I've tried without a GPU, with out any HDD/SSD's the same every time.
Any Ideas..??
My setup is.
I5 4690K
2x8gb Corsair DDR3 Ram
MSI GTX 960 (OLD)
EVGA GTX 980Ti (New)
Corsair RMi 850W PSU
https://linustechtips.com/topic/579595-not-posting-and-reboot-loop/
Have you tried clearing the BIOS settings?
MSI Nightblade MI2
CPU: Intel i7 6700. Motherboard: MSI B060. RAM: 16GB HyperX Impact. GPU: MSI Geforce GTX 970. Case: Nightblade MI2. Storage: 2x 1TB WD Blue, OCZ 120GB and 125GB M.2. PSU: Custom 350w Bronze. Display(s): BenQ 24" & 50" Samsung TV. Keyboard: Logitech G15. Mouse: Logitech MX Revolution. Operating System: Windows 10 Pro x64
5 minutes ago, NexoPlay said:
Thank you for your reply.
I have just tried the clear CMOS button on the board and it does not help unfortunately :-(
Is there any chance one of the components have before dislodged during the swap? I would remove the CMOS battery and check all the components are seated properly.
MSI Nightblade MI2
Was the system overclocked?
MSI Nightblade MI2
I've just tried to remove the CMOS battery and that unfortunately did nothing. :-(
The closets article I could find with the same Q Code suggest the CPU. Most of the problems in the articles started after component change.
http://www.tomshardware.co.uk/answers/id-2830216/maximus-gene-vii-code-pre-memory-system-agent-initialization-started.html
Code 15: RAM or Motherboard.
Code 00: CPU or Motherboard.
MSI Nightblade MI2
Okay I got some thermal paste from a friend, and tried to take the hardware out of the case and test it on the table. Hooked up one component at a time to make sure everything worked..
All worked fine, and I started putting things back in the case, again testing for post with every component.
As everything was back in the case, I turned it on, it booted into Windows, I tried to create a folder on one of my drives and it crashed and started all over again.
I thought okay it's the drive, disconnected the drive and hit the power button, no luck.
im out of ideas by now. ??
