PC power usage suddenly doubled
Go to solution Solved by Moonzy,
1 minute ago, 19_blackie_73 said:
jep that's it, it is running at 1177MHz...  WHY???? (not a direct question to you but if you have a clue why pls give me a hint how i get the clock down...)
try installing the latest AMD driver if you're on AMD cards, or the 362.xx or the 361.xx drivers if you're using nvidia cards
it could be that something is using your gpu? i dunno
your gpu should down clock itself during idle
Hey guys,
recently my PC's idle power consumption simply doubled with no changes to anything (no driver updates or sim.). Before it was at 40-50W idle, now it is at 100W idle. what causes this?
Thanks in advance for any tips tricks and thoughts!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/578532-pc-power-usage-suddenly-doubled/
@Moonzy didn't find anything abnormal, cpu is according to task manager at 0-4% at 0,78Ghz
- Ryzen Build -
2x Dell UP2516D
3 minutes ago, Samfisher said:
Power Options set to Maximum Power?
i tried the energy saving profile of win10, didn't change anything.... :(
- Ryzen Build -
2x Dell UP2516D
Your CPU and GPU clock speeds while idle?
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
@Matthew_innes @Moonzy@Samfisher: just restarted the computer: When on the login screen, power usage is normal (40-50W), but as soon as everything is loaded, it is that high. I opened msconfig and checked hide windows services, there are only avira and nvidia which are starting services.
I have sth like that:
- Ryzen Build -
2x Dell UP2516D
well... being on the desktop does run more task than being on the login screen, so that explains it lol
-sigh- feeling like I'm being too negative lately
yeah but I achieved the 40-50W on the desktop until last week or so and i didn't install anything
- Ryzen Build -
2x Dell UP2516D
probably some background softwares that arent registered on the task manager (like windows's own programs)
also, check if your gpu is stuck running at high clock speeds, that might be one of the issues
- Ryzen Build -
2x Dell UP2516D
jep, just checked it: in other windows users it does downclock, but in my standard one not....
- Ryzen Build -
2x Dell UP2516D
solved the issue, but it is very strange that this problem only occured in this particular winuser
- Ryzen Build -
2x Dell UP2516D
