Hi ,
Ive just build my first PC inside the beautiful inwin 901 case, specs are as follows :
-I5 4690k
-R9 270(upgrading later this year)
-8gb ddr3 ram( also upgrading to 16 as soon as possible)
-asrock  h81m-itx
-550watt corsair PSU
My concern is I bought an overclockable CPU and I want to take advantage of that and hope to boost it to about 4.5/6ghz , however ive seen a lot of reviews about my mobo that say that some air coolers don't fit as the get in the way of the ram , water cooling could be an option but fgen again it causes a large issue when you want to plug something in you have to take it all apart, does anyone have any recommendation?
https://linustechtips.com/topic/578498-inwin-901-cooler-help/
1 hour ago, Galbarello said:
Hi ,
-I5 4690k
-asrock  h81m-itx
if I recall correctly, that mobo isn't very good for OC. So I've wouldn't overclock too hard on that board. just buy a hyper 212 evo
https://linustechtips.com/topic/578498-inwin-901-cooler-help/#findComment-7563861
You may want to check that a hyper 212 evo wouldn't have clearance issues with the case you're using. For the 901 I'd go for something like a noctua NH-L9x65. Gives a bit of OCing headroom and you should be able to get pretty much any RAM without clearance issues.
Edited by Oneofmanyjacks
https://linustechtips.com/topic/578498-inwin-901-cooler-help/#findComment-7570517
why did ye quote me mate? wrong quote.
https://linustechtips.com/topic/578498-inwin-901-cooler-help/#findComment-7570618
