Raid for first build
Go to solution Solved by Bittenfleax,
As long as you buy an expensive high-end motherboard with a good raid controller on it. However, there are some things to keep in mind:
1. Why RAID 1? What "important" data/OS will you be running? Could a cloud service be a better option to store sensitive info?
2.The price. You have to buy two drivers now. Also, a high end motherboard with good raid controller. (Also, going back to Cloud for a cheaper service) (or a dedicated raid controller which are a lot although I think you can get cheap second hand ones but that would be defeating the object of keeping data safe if you buy an old 'used' controller)
If you have the 'cash to splash' then sure! Why not?! It will be fun and you can learn on the way. If you don't really want to spend much then you can use the Cloud (there are many services from which you can choose, a quick Google search should return the best ones) to save all of your sensitive data.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/578495-raid-for-first-build/#findComment-7563646
